Skip to Content
Apothecary Chest Plan
June 19, 2026 by
Unleap, Nazareno Guzman [Unleap]
The 16-Drawer Apothecary Chest
Here’s a great piece of furniture that will solve a BIG storage problem – where to put those sewing supplies, scissors, decks of cards, cassette tapes and dozens of other “odds-n-end” items that seem to keep cluttering up the house. Designed to resemble the chests used in old-time drugstores, this Apothecary Chest has 16 generous sized drawers to accommodate lots of things.
We built our chest out of #2 common pine throughout, except for the hardboard back and drawer bottoms…but poplar, cherry, oak or virtually any wood will look great. If you like, you can even save some money on materials by using particleboard for the partitions and plywood for the drawers.
1: Cut out the Sides (A), Top (B), Base Pieces (G & H), and Drawer Fronts (K). This will allow you to select the most attractive wood for the visible parts. Be sure to cut the drawer fronts (K) to about 1/8″ oversize, since the finished drawer sides and bottoms are sanded flush after final assembly.
2: Cut the remaining stock to size, according to the list of materials. We glued-up the 14″ wide partitions (C) out of solid pine, but you could also make these partitions out of 13-1/4″ wide particleboard or plywood, then glue and nail a 3/4″ x 3/4″ strip of pine (or matching wood) facing to the exposed edge.
3: Form the 1/4″ deep by 3/8″ wide rabbet in the back edges of the sides (A) to accept the chest back (J). You can do this by making two cuts with an ordinary saw blade…or by using your Dado Set.
4: Attach the drawer guides (E) to the partitions (C) with 4-penny finishing nails and glue. Mount the guides flush with the back edges of the partitions, being sure to leave a 6-1/16″ spacing between each guide. We temporarily positioned a 6-1/16″ wide piece of scrapwood between each guide during assembly to maintain the exact distance. Attach the 3/4″ x 3/4″ filler strip (D) to the top
5: Assemble the sides (A) and partitions (C) with glue and 8-penny finishing nails. Be sure to double-check your spacing to make sure you have 6-1/16″ of vertical spacing between each partition. Glue the drawer dividers (F) into place.
6: Shape the edges of the top (B) and the drawer fronts (K) with your Shaper set-up and 1/4″ Quarter-Round Shaper Cutter. As an option, you could also use your Router Package with a 1/4″ Router Chuck and a Round Over Bit. Shape just the sides and front edge of the top.
7: Attach the top (B) to the case, using 8-penny finishing nails – then attach the back (J) with 2-penny common nails or small brads.
8: Miter the corners of the base pieces (G & H). Cut the scrollwork using your Bandsaw or Scroll Saw . Once you’ve made the cuts, smooth them with your Drum Sander. Attach the base pieces, using 4-penny finishing nails and glue.
