Skip to Content
Candle Sconce
June 19, 2026 by
Candle Sconce
Unleap, Nazareno Guzman [Unleap]
The Early American Candle Sconce
Here’s an attractive, early American style wall sconce that’s universal enough in its design to fit well with practically any home decor. Plus…you can sell them individually, or in pairs to grace both sides of a hall mirror, window, fireplace mantle or wall collage. We made ours from poplar with a walnut stain, but cherry, maple, oak, mahogany or virtually any hardwood will work fine for this project and look great when finished properly.
Begin by making the patterns for both the Back and Chimney Platform from pieces of 1/8″ to 1/4″ masonite or hardboard.
Cut out the shape for the Back pattern, using your bandsaw, scroll saw or sabre saw and sand the edges smooth with a small diameter drum sander. When making your pattern for the Chimney Platform, be sure to drill a small, 1/32″ diameter through-hole at the center point, where the Candle Cup will be mounted.
Trace the Back pattern onto your workpiece, cut out the Back and sand the edges smooth, as you did when making your pattern. If you have a bandsaw or scroll saw, you can pad saw multiple pieces at once (up to the cutting depth limits of your saw) by temporarily attaching them together with double-stick tape, then separating the individual Backs once you’ve cut them out.
Cut out the 4-1/2″ x 5″ blanks for the Chimney Platform. Use your Platform pattern to mark the center by inserting a small wire brad through the 1/32″ hole and tapping it with a hammer. Using a pencil compass with a soft, #1 or #2 lead, clearly mark the position of the 3/16″ deep circular groove that will hold your glass chimney (determine this diameter from the chimney you plan to use). Once you’ve drawn a dark, easy-to-see circle for your groove location, use a 1/8″ diameter drill bit to bore a pilot hole all the way through the Platform stock at the circle centerpoint.
