Skip to Content
Classic Roll Top Desk
June 19, 2026 by
Unleap, Nazareno Guzman [Unleap]
Eight side drawers and a generous sized lap drawer give you plenty of storage for all your important office supplies.
Have you ever considered building a major piece of furniture like this handsome roll top desk? It’s not really difficult – just a matter of making some basic saw cuts, fitting, drilling, dadoing, gluing…operations that are basically very simple. The secret is — TAKE YOUR TIME! Pay careful attention at every step along the way. “Measure twice and cut once.” If you follow these simple rules of furniture construction, you’ll be surprised at how smoothly the job will go, and how proud you’ll be of the results you achieve.
Since this is a rather difficult project, we’ve decided to present the plans and procedures for building it in two parts. First, we’ll tackle the pedestal desk base. Then, in the upcoming March/April edition of Hands-On, we’ll build the rolltop unit that goes with it.
Once the base is completed, you’ll have an extremely functional and beautiful piece of furniture. Then, when the rolltop section is finished and attached to the assembled desktop (no special joinery is required), you’ll have a true family heirloom that you’ll be proud to pass along to future generations.
*Front Frame Pieces (D) are exposed and should be made out of the same stock as the rest of the exterior. Back Frame Pieces (E) are NOT exposed and therefore may be made of secondary wood.
1: PLANNING
The most important aspect of building any piece of furniture is planning. Start by looking over the printed plans very carefully. Read all the how-to information. Review the List of Materials and the drawings.
While you’re looking over the plans, be sure to take some notes regarding special operations, tools you might be needing, assembly techniques and shop safety — “building” the project in your mind, step-by-step.
The original plans for this desk were purchased from one of the major furniture plan developers, then modified to our liking after clipping photos of some desks we liked from magazines and other sources. Some minor changes were made to suit our special needs. For example, we used 3/4″ lumber for the pedestal base pieces instead of the 1/2″ used in the printed plan…then added three drawers on the rolltop section.
We often use available project plans for certain projects, then modify their features and measurements to suit our special needs.
Phase 1
2: GETTING STARTED
To build this project, you’ll need two sheets of 3/4″ oak veneer plywood. When buying the plywood, try to select two sheets with a similar grain pattern. For the drawers and other interior parts, you’ll need some poplar or pine. Remember, if you select blemished or damaged materials when you’re beginning, you’ll probably wind up with discouraging results in the end. Choose your materials carefully. If you go to a lumber retailer who refuses to let you choose your pieces, walk out and go to a different lumber retailer who will.
3: CUT THE PEDESTAL SIDES (B)
Start by laying out the sides (B) and pull-out drawboards (P) on a piece of your 3/4″ plywood. Make sure the grain direction follows the longest dimension of the parts. Start by cutting the plywood into manageable sized pieces, then trim them to their finished size. Shopsmith’s Crosscut Sliding Table will help you crosscut larger sized pieces with improved accuracy
4: CUT THE DADOES & RABBETS
In the sides (B), using your Dado Attachment or Router Package. Note that all dadoes are to be cut to 1/4″ deep. Since you’ll be performing the same operation on a total of four pieces, keep your MARK V at the same setting until you finish the identical cuts on the remaining three.
5: MAKE THE DUST PANELS
Again, use production techniques to make all of the parts of these panels at once. First, rip parts D, E, F, G, H & J to the same width. Note that the edges of the (8) front frame pieces (D) will be exposed and therefore, should be made from the same wood as the exterior of the desk.
Next, cut the frame pieces to final length, then form a 1/4″ wide by 1/4″ deep groove in one edge of each piece. You’ll need to take two of the front frame pieces (D) and form a groove on the top back side.(see drawing detail “A”)
Form 1/4″ by 1/4″ long stub tenons on the ends of the frame sides (F, G, H). Cut the 3/4″ wide by 1/4″ deep notches in the corners of the front frame pieces (D) to accept the pedestal facing strips (T).
Next, cut the plywood dust panels (U, V, W) to size and glue up the dust panel assemblies. Use yellow woodworker’s glue, being careful not to get any glue on the plywood panels, since they should “float” loosely in the frame pieces. When clamping the pieces, make sure they remain square and flat. Set the center panel aside.
6: ASSEMBLE DUST PANELS TO SIDES (B)
With glue and clamps. The frames mount flush with the back edge of the sides. Be sure to line up the notches on the fronts of the frames with the front edges of the sides.
Cut the bottom rails (C) to size and attach these with glue and 6-penny finishing nails.
7: ASSEMBLE THE REMAINING PARTS OF THE BASE PEDESTALS
First, attach the pedestal facing strips (T) to the exposed edges of the sides. Next, cut the pedestal backs (Y) to size and attach with 2-penny nails.
Make the pedestal base pieces (L & M) and use your Shaper or Router Package to form a decorative edge on the tops of these pieces, if desired. If you’re using a Shaper set-up, try the 1/4″ and 1/2″ Combination Quarter-Round Cutter or an Ogee Cutter. If you’re working with your MARK V Router Package, you could use a 3/8″ Round-Over Bit or the 5/32″ Roman Ogee Bit.
Miter the pieces to fit the Base, then use your Disc Sander to “shave” the mitered edges down for a perfect fit. Attach the pieces to the base with glue and 6-penny finishing nails. Use a nailset to countersink the nail heads, then fill the holes with a high-quality, stainable wood putty.
