Skip to Content
Duck Napkin Holder
June 19, 2026 by
Duck Napkin Holder
Unleap, Nazareno Guzman [Unleap]
Here’s a great Scroll Saw project for those late Summer/early Fall craft fairs
Fire-up your Scroll Saw (and Bandsaw) and get started on these quick, easy-to-make Duck napkin-holders. All you’ll need is some wood, a roll of Double-stick tape, a few bucks worth of paint and a little time.
Begin by deciding what type of stock you’re going to use. We selected poplar for ours because of its straight grain, easy working ability and the fact that we had planned to apply a filler and paint the finished ducks, anyway. Another option would be to make them out of attractive hardwoods such as cherry, walnut or oak and stain them or finish them with a natural oil instead of painting. It’s your choice.
Start by transferring the pattern from the drawing onto a piece of 7/16″ thick stock. Or even better, print the pattern out and make photo copies to the size you need. Decide how many ducks you want, and make one photocopy for every four ducks (if you’re planning to pad saw them out, four at a time). Fasten your four-blank stacks together using Double-stick Tape, then merely glue a fresh pattern on the top blank in each stack (using artist’s spray-on glue) and go to work. Much faster and easier.
