Skip to Content
Folding Party Tray
June 19, 2026 by
Folding Party Tray
Unleap, Nazareno Guzman [Unleap]
Here’s a great project to hlep you be prepared for those upcoming Summertime deck or patio parties.
You’ve planned a cookout and your guests are scheduled to arrive in 15 minutes. You’ve already dragged that wobbly old card table out just one more time and set it up beside your picnic table on the patio or deck. But you still don’t have enough space for all your guests. So, you’re back in the house, scrounging around for more tables when the doorbell rings. You open the door and there they stand…as if they all arrived in a single bus. A quick count and your worst nightmare becomes reality…you have four more guests than places to seat them. Your four closest friends end up in folding chairs with paper plates full of food balanced precariously on their knees and barbecue sauce dribbling down their pant legs. GREAT!
Next time, get those plates off their laps and give them a place to ENJOY their meals with these handy, fold-away party trays. Made of redwood (or any wood of your choice), they’re not only utilitarian, but beautifully designed and easy to build, too.
Getting StartedTo build the project, you’ll need your MARK V (or a table saw) and jointer for making your sizing cuts (the jointer is optional)…a drill press (or your MARK V) for boring the bolt and screw holes…a bandsaw or scroll saw and a disc sander to round and smooth your parts.
HARDWARE
(2) 1/4 “-20 x 1-1/2” carriage bolts
(2) 1/4 “-20 x 2-1/4” carriage bolts
(4) 1/4 “I.D. flat washers
(4) 1/4 “-20 locking cap nuts
(26) #8 x 2″ roundhead wood screws
(28) #8 I.D. flat washers
(2) #8 x 1″ flathead wood screws
(8) #8 x 1-1/2″ flathead wood screws
A
Legs (4)
3/4 x 2-1/8 x 28
B
Lower Brace (1)
3/4 x 2-1/8 x 22-1/2
C
Spacer (2)
3/4 x 1″ outside diameter
D
Upper Brace (1)
3/4 x 2-1/8 x 19-1/2
E
Dowel Brace (1)
3/4 dowel – 19-1/2 long
F
Brace Lock (2)
3/4 x 2-1/8 x 3-13/16
G
Skirt (2)
3/4 x 2-1/8 x 15-5/8
H
Top (4)
3/4 x 3-13/16 x 24
Component Construction
Before you get started, keep in mind that since all the tool set-ups for this project are so simple, it’s almost as quick and easy to go ahead and make six or so of these trays, while you’re at it. Making more is a simple matter of running additional lumber through your machinery. Of course, you’ll need a little extra assembly time too, but you’ll quickly discover that it’s a lot easier to make more trays now than to go back and re-do all your set-ups for another “run” at a later date. So, think about how many you might need and “do it now”. You’ll be glad you did.
Since our plan calls for outdoor use, we used redwood for our trays. It’s attractive, light in weight and resistant to decay. However, you could just as easily make these trays out of virtually any clear, attractive lumber. The choice is yours.
Start by using your table saw to cut all of your pieces (A,B,D,F,G,H) to size, as shown in the Bill of Materials. Rip everything to width first, making all your pieces just a “hair” oversized so you can run them over the jointer to smooth the edges prior to assembly…then crosscut them to length.
Cut out an extra piece, from which you will cut however many small, round spacers (C) you may need for the number of trays you plan to build. Use a pencil compass to draw a sufficient quantity (two per tray) of 1″ diameter spacers on this piece of stock.
Next, lay out the holes for the carriage bolts and dowel braces (E) in the four legs. Using a 3/4″ Brad Point Drill Bit, bore the through-holes for the dowel brace (E) and the 1/4″ deep counterbore holes (for the carriage bolts). Note that for each tray, two of the legs have a through hole at the top end…the other two legs have a counterbore at the top end…and all four legs have a counterbore near their centers.
A DRILLING TIP: If you’re using the MARK V drill press setup, set your rip fence to establish the hole centerline on your leg boards. Using the same 3/4″ bit, drill the through holes in the brace locks (F) that will form the back sides of the notches that will accept the dowel brace (E) when the trays are opened…and the 3/4″ internal radius at the left end of each Skirt (G) to accept the dowel brace when the trays are closed.
