Skip to Content
Dovetail Carbide Router Bit
Shopsmith carbide-tipped router bits have been designed for working with hardwoods, laminates in a production or home shop environment. Each features rugged carbide tips to take and hold a keen cutting edge, with infrequent sharpening.
All have 1/2-inch shanks for use in the Shopsmith 1/2-inch router chuck (514631). A step up from our standard, high speed steel bits.
• 3/4" Straight Carbide-Tipped Router Bit (521870)
• 1/2" Straight Carbide-Tipped Router Bit (521869)
• 3/8" Straight Carbide-Tipped Router Bit (521868)
• 1/4" Straight Carbide-Tipped Router Bit (521867)
• 1/2" Dovetail Carbide-Tipped Router Bit (521866)
1/2” Shopsmith Router Chuck turns your MARK into a great overhead Router Table (514631)
This precision machined tool steel Router Chuck has been especially designed to slip onto your MARK V’s 5/8” Spindle and firmly grip any 1/2” shank Router Bit for over-table routing operations.
Made specifically to handle the side thrust associated with Routing. This Router Chuck features two setscrews to grip your Router Bit firmly and a third setscrew to grip your MARK V’s spindle.
CAUTION: Do NOT attempt to perform routing or similar side thrust operations with your 1/2” drill chuck, as this will damage your Chuck.
1/2" Router Chuck with Guard (555191)
Chuck withstands the side-thrust typically accompanying routing operations.
Precision-machined from fine tool steel for exceptional durability. Two Setscrews hold virtually any bit or attachment securely. Comes with Shield. 1/2" shank bits only! The Clear Shield protects hands and eyes. The brush knocks down the flying chips and dust to make dust collection more effective.
Shopsmith ¼” Router Chuck allows you to hold ¼ Inch Shank Bits Tightly and Securely (514632)
Holds ¼” Shank router Bits in a similar fashion as the ½” Router Chuck above PLUS -- Also lets you use Shopsmith's Drum Sanding Set on your Belt Sander's Auxiliary Shaft. Just slip this Router Chuck onto your Belt Sander's Auxiliary Shaft and you'll be ready to Drum Sand all types of projects with our 1/4" shaft Drum Sanding Set. A better choice than using your Drill Chuck, since most geared Chucks (including ours) are not designed to withstand side deflection pressure.
1/4” Router Chuck with Guard (555189)
Precision-machined from fine tool steel for exceptional durability. Two Set-screws hold virtually any bit or attachment securely. Comes with Shield. 1/4" shank bits only! The Clear Shield protects hands and eyes. The brush knocks down the flying chips and dust to make dust collection more effective.
Create Beautiful Designs and Perfect Dovetail Joints and Rabbets with the Shopsmith Router Package (555176)
Create beautiful designs and perfect dovetail joints and rabbets with these router bits. Get exceptionally clean cuts with super-smooth edges so that all your work has that professional finish.
Package Includes: Router Chuck and Shield, 1/4", 3/8", 1/2", 3/4" Straight bits and 1/2" Dovetail Router Bits.
Router/Shaper Shield Puts Safety Back into Shaping and Routing (555373)
This see-through shield clamps around your Mark 7 or Mark V quill with a single setscrew and provides both front eye protection and a rear brush that can be adjusted to meet the top of the fence or your workpiece for added dust collection efficiency. Standard with router and shaper packages.
Note: Not for use with 10-ER, Mark 2 or older-style Mark VII.
SKU: 521866
34.95 34.95
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
