Skip to Content
Bandsaw Clear Plastic Window for Bandsaw Cover
Make Your Bandsaw Look Like New Again with a New Bandsaw Cover (522221)
Shopsmith Bandsaw Cover allows you to Tension the Blade AND see the Blade Tension Scale when adjusting your blade tension without ever having to remove the cover! Simply insert the 5/32" Allen wrench through the side of the cover to make this adjustment. Then before storing. it is easy to reduce tension without ever removing the cover. The Cover also has an arrow to take the guess work out of which way your blade should run.
If you've been putting off ordering a new cover, now is the time to make your Bandsaw look new again!
See the Tension Scale Without Looking Through Scratches with the Bandsaw Clear Plastic Window (for Bandsaw Cover) (522217)
Is reading the numbers on the Tension Scale has become difficult? It is time to replace the clear Plastic Window NOW. This new window will simply snap in place. No glue or hardware is required.
Add a new Dust Chute to an old Bandsaw Cover or add Additional Dust Chutes to Your Newer Cover with the Band Saw Dust Chute (300000)
Eliminates Dust At the Source. Suck-up damaging sawdust to keep your shop clean and your Bandsaw operating at its best. One dust Chute works well directly under the table. Many of our customers tell us a second Dust Chute at the bottom of the Cover, directly under the first, adds to the dust collection efficiency.
Includes Dust Chute, all mounting hardware and instructions.
Protect Your Hands from the Spinning Bandsaw Shaft with the Bandsaw Shaft Guard Upgrade Package (522251)
This guard is easily mounted over the Shaft. Use the enclosed Template and Instructions to quickly install this Shaft Guard with four screws, in just a few minutes.
Includes Shaft Guard, Mounting Template, Instructions and Hardware.
SKU: 522217
15.95 15.95
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
