Skip to Content
Bandsaw Cover Upgrade with Window and Dust Port
The Bandsaw Cover Upgrade with Window and Dust Port allows you to tension the blade and see the blade tension scale when adjusting your blade tension without ever having to remove the cover. Simply insert the 5/32" Allen wrench through the side of the cover to make this adjustment. Then before storing, it is easy to reduce tension without ever removing the cover. The cover also has an arrow to take the guess work out of which way your blade should run.
SKU: 522221
99.95 99.95
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
