Skip to Content
Rip Scale Complete Kit (MARK 7/MARK V 520/MARK 4)
Install this Rip Scale Upgrade Kit and in about a half-hour, you'll be instantly setting rip cut dimensions with lightning speed and matchless precision.
A powerful magnetic strip attached to the top of each rail holds your choice of a short or long precision Stainless-Steel scale that is graduated in both, 32nds and 16ths. Choose the long 45” scale when measuring cuts between 6-1/2" from the left of the blade to 38-1/2" from the right. Scales will also read in opposite direction, except numbers will be upside-down. Or, the short 16” scale when measuring cuts between 6-1/2" from the left of the blade to 9-1/2" from the right.
Zeroing-adjustments are easily made by simply sliding the steel scales on their magnetic holders. Once positioned, they will remain where you put them without shifting.
The kit includes:
• A new 17-1/2" Front Rail for your main table
• (3) 7-1/2" Front Rails for your extension tables
• 16" Long Stainless-Steel Scale
• 45" Long Stainless-Steel Scale
• Wide, Easy-to-read Scale Indicator
• Complete Instructions and All Required Installation Hardware
Note: For use with MARK V 520 Pro Fence System Only.
SKU: 522292
209.95 209.95
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
