Skip to Content
Shopsmith 4 Inch Jointer
Jointers have Many Great Uses which make them a necessity in the Shop Including Flattening, Straightening and Truing-up Project Pieces.
Jointers are used to smooth and square board edges in preparation for glue-up into wider panels perfect for cabinet and furniture projects or really any woodworking project.
Here's Why the 4" Jointer Provides The Most Value!
Because many wood projects require long or wide boards, some may think a larger Jointer is required. Actually, the Shopsmith 4" Jointer is the perfect size for a large majority of woodworking projects. Having a Jointer larger than 4" can sometimes be helpful for more obscure projects, but it can also be more than you need and the excess cost doesn't provide the added value! If Your Jointer is going to be used primarily for planing the edges of boards (with only an occasional need to surface narrow stock) - and since few people work with stock thicker than 4" - why pay for capacities you just won't use? In addition, Larger Jointers weigh hundreds of pounds making them difficult to lift or move.
Here are Juist Some Other Jobs Your Shopsmith Jointer will Handle Nicely:
Bevel or Chamfer Edges - Create smooth, precisely beveled or chamfered edges on boards for angled cabinetry; making decorative interior or exterior columns; creating a bowl or vase glue-up for lathe turning; or cooperage (barrel/container-making) projects. No Sanding Required!
Eliminate Cupping - Boards are often cupped or hollow on one side. As long as they're no wider than 4", you can eliminate this cupping with a few light Jointer passes. This will, of course, change board thickness.
Square Large Stock - Squaring large (thick) stock on a table saw can often tax its capabilities... especially with resinous woods. Use your Jointer to deliver a perfect 90° angle on stock up to 4" thick every time. No Sanding Required!
Form Precision Edge Rabbets & Tongues - (up to 3/8" deep) - Form a perfect, 90° rabbet or tongue (for tongue-and-groove joints) along the edge of a board with your Shopsmith Jointer. No Sanding Required!
Loaded with Work-Saving, Results-Enhancing Benefits and Accessories!
As with all Shopsmith Special Purpose Tools, your Jointer offers a number of great features and accessories to help you make everything you make - better.
MARK or Stand Mount Every Shopsmith Special Purpose Tool offers you the option of mounting and powering it with your Shopsmith MARK- or with its own, individual, motorized Stand.
Safety Feather Guard Special Guard is spring-loaded to exert continuous pressure against the workpiece, forcing it against the fence while you make your cuts. To increase or decrease tension, just loosen the tension adjustment Knob, move it along its adjustment arc and tighten.
Simple Knife Leveling and Clamping System Your Shopsmith Jointer's individual knife leveling screws let you adjust each knife end up-and-down individually to compensate for variations created during sharpening. As a result, you'll be able to sharpen your own knives using our special Planer/Jointer Knife Sharpener, without the need for costly professional match-grinding.
Full Tilting Fence The fence on your Shopsmith Jointer tilts up to 45° left or right and offers adjustable auto-stops at common angles for rapid adjustment convenience.
Built-In Dust Collection Chute Built-in 2-1/2" dust collection chute helps you capture the dust and debris before it gets into the shop environment.
Specifications:
• Maximum Width of Cut - 4"
• Maximum Depth of Cut (Single Pass) - 3/8"
• Maximum Depth of Rabbet Cut - 3/8"
• Infeed Table - 5-1/2" x 13-1/4"
• Outfeed Table - 4-1/2" x 13-1/4"
• Overall Table Length - 28"
• Fence - 3" x 21-3/4"
• Fence Tilt - 45° left to 45° right
• Fence Auto-Stops (Adjustable at) - 45°, 90° and 45°
• Cutterhead Diameter - 2-1/2"
• Knives - 3 Precision-Ground Steel
• Bearings - 2 Sealed, Ball Bearings
• Speed (Recommended) - 3,900 - 6,200 rpm
• Weight - 53 lbs.
Mounts on MARKs, Power Stand or Power Station.
Buy The Shopsmith Jointer - Your Best Value for Smoothing, Straightening and Squaring Project Components!
SKU: 555483
849.95 849.95
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
