Skip to Content
Bandsaw Circle Cutter Attachment
Add the Shopsmith circle cutter to your bandsaw and cut perfect circles from 2" to 36" in diameter, quickly and easily. Just attach the circle cutter to your bandsaw table extension (555488) with a single bolt. Use the single adjustment knob to position the center pin for your desired diameter and stock thickness and pivot your workpiece through the bandsaw blade to cut perfect circles from 2" to 36" in diameter. It's just that simple!
The heavy, twin steel bars provide plenty of rigidity while the single adjustment knob makes setting your desired circle size both fast and precise. If necessary, the center pivot pin adjusts up and down, then locks into position with a wing nut.
Handles any thickness of stock, all the way up to your bandsaw's maximum 6" depth-of-cut.
Note: Works only with newer model aluminum table Shopsmith Bandsaws and requires the bandsaw table extension (item 555488) for attachment.
SKU: 555489
69.95 69.95
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
