Skip to Content
Bandsaw Accessory Kit (Bandsaw Fence, Table Extension, Circle Cutter)
The Bandsaw Accessory Kit (Bandsaw Fence, Table Extension, Circle Cutter) is the perfect upgrade to get the most out of your Shopsmith Bandsaw if you already have the aluminum bandsaw table. The kit comes with the following:
• Bandsaw Rip Fence (for improved straight-line cutting results)
• Table Extension (adds 11-1/2" of outboard table support)
• Circle Cutter (helps you create perfectly round circles).
For more details on each part in the complete kit, see below.
Bandsaw Fence Upgrade (555645)
The upgraded bandsaw fence delivers improved straight-line cutting results. The self-aligning aluminum fence locks firmly into position on the band saw table with a twist of the handle and a flip at the locking lever, and adjusts from 0" to 5" from blade. Accepts fence mounted accessories such as flip-up stop, T-track mounted utility light and featherboards.
Note: For use on Shopsmith bandsaws with aluminum tables only (as shown here).
Table Extension Upgrade (555488)
The upgraded table extension adds 11-1/2" of outbound support for improved workpiece control and precision.  Just slip the twin steel mounting rods into the two holes in the front edge of your (newer model) Shopsmith cast aluminum bandsaw table and tighten the two locking knobs (included with the table extension). Provides loads of extra support and stability when cutting larger, more cumbersome workpieces.
Bandsaw Circle Cutter (555489)
Add the Shopsmith circle cutter to cut perfect circles from 2" to 36" in diameter, quickly and easily. Just attach the circle cutter to your bandsaw table extension (555488) with a single bolt. Use the single adjustment knob to position the center pin for your desired diameter and stock thickness and pivot your workpiece through the bandsaw blade to cut perfect circles from 2" to 36" in diameter. It's just that simple!
The heavy, twin steel bars provide plenty of rigidity while the single adjustment knob makes setting your desired circle size both fast and precise. If necessary, the center pivot pin adjusts up and down, then locks into position with a wing nut.
Handles any thickness of stock, all the way up to your bandsaw's maximum 6" depth-of-cut.
Note: Works only with newer model aluminum table Shopsmith Bandsaws and requires the bandsaw table extension (item 555488) for attachment.
SKU: 555668
299.95 299.95
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
