Skip to Content
Dial Indicator Alignment Gauge
Set-up or Tune-up Your Tools and Operations with Precision, Using The Shopsmith Dial Indicator Gauge (555884)
This gauge will help You align Your MARK (for All MARKs) worktable, rip fence or miter gauge pre-sets for precise cuts, time-after-time. Align Your miter gauge to an exact 45° or 90° setting. Achieve the smoothest edges and surfaces by match-setting Your jointer knives. Micro-adjust the offset of shaper and router table fences. Set the depth-of-cut for saw blades, dado blades, router bits and more with amazing accuracy. Measure the depths of holes or dadoes the list goes on.
Includes:
• Large 2-1/4" Diameter Dial Indicator, graduated in 1/1000 (.001") with a full 1" range
• Set of 22 Interchangeable Indicator Points for tackling the toughest measuring jobs
• Special Mounting Block with Adjustable Bracket
• 5" Long Miter Bar and
• Easy-To-Follow Illustrated Instructions.
Critical MARK V Alignments – Works Great for All Other MARK Models as Well! – NOW Streaming or DVD! (556062)
Hosted by Nick Engler, former editor of Shopsmith's original Hands-On! Magazine, this fail-safe, step-by-step, 68-minute video leaves nothing to chance as Nick leads you through aligning your MARK V's major components to achieve the very best results.
A fantastic HOW-TO video from Nick Engler that shows you, step-by-step how to align your MARK V’s major components quickly and easily so you can achieve the very best results on all of your projects. No more fiddling around, no more guesswork - Just the facts!
What you’ll learn in these four, fail-safe sessions:
How to align the main Worktable with the Sawblade Since most projects begin with sawing your workpieces to size, this is the most important of all alignments. In this segment, you’ll learn how to set your Worktable Miter Gauge slots to be parallel with the axis of rotation of your sawblades.
How to align the Miter Gauge & Rip Fence to the Worktable Miter Gauge slots In this segment, Nick shows you how to be sure your Rip Fence is parallel with these slots and your Miter Gauge face is perpendicular to them. He also shows you how to set the two 450 stops on your Miter Gauge.
How to align the Worktable with the Drill Chuck In this segment, you’ll learn how to be certain that your Drill Chuck is aligned perfectly with the Worktable surface, both front-to-back – and left-to-right. Only be doing this, can you be sure that the holes you drill, grooves you rout, edges you Drum Sand and more are at the desired angle to your workpiece surfaces and edges.
How to align your Floating Tables and Extension Table Since your Rip Fence can be used on these Tables as well as your Main Worktable, it is critical that they be in perfect alignment with the Main Worktable. In this segment, Nick shows you how to make the adjustments that will ensure the precision of your rip cuts and other operations that may rely on the accurate positioning of your MARK V Rip Fence.
Order this 68-minute video and pick up loads of great of techniques on how to align your Shopsmith MARK for optimal performance and improved woodworking results!
BUNDLE & SAVE
Get the Alignment Package with Both the Shopsmith Dial Indicator Gauge and the Critical MARK V Alignments (Streaming or DVD) and Save!
Videos
Watch these online videos to see this amazing tool in action
Aligning the MARK V Table
Setting Jointer Knives
SKU: 555884
109.95 109.95
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
