Skip to Content
MARK V 505 to MARK 7 Pro Table System Upgrade
The Pro Fence System Upgrade gives you everything you need to step your Mark V Model 505 up to the complete workpiece Table Support System and Enhanced Rip Fence of the MARK 7 Pro Fence & Table System.
The professional-duty self-aligning, Pro Fence System features two interchangeable stainless-steel scales for direct-reading of rip cut widths. Includes twin locking levers, one for the infeed end of the fence and one for the outfeed end to ensure a positive, precise fence lock-down, even when working with large or heavy workpieces.
Your new Rip Fence drops straight down onto the fence rails without tipping or fiddling, then slides easily and precisely along the rails on high-tech glides. The two floating tables and fixed extension table rails feature a 3-point locking system to ensure that your fence is always parallel to the blade. Two complete floating extension tables with four 27" connecting tubes and two telescoping support legs with adjustable fittings are included. These allow you to slide the floating tables anywhere between the main worktable and fixed extension table.
Included in the Pro Fence & Table Upgrade Kit:
  • Rip fence is 24-1/2" long x 2-1/2" thick with four T-slot tracks. Two on the top surface and a T-slot track on each side
  • 2 Direct-reading rip fence scales. 2 magnetic, stainless steel scales, 1 45" long and one 16" long
  • Wider fence straddler made to fit the wider rip fence
  • 2 rails for main worktable with magnetic strips for the stainless steel scales
  • 2 rails for extension table with magnetic strips for the stainless steel scales
  • 2 fully assembled and aligned floating extension tables
  • 4 27" connecting tubes
  • 2 telescoping legs
  • All required fittings and hardware
  • Instruction manual
  • (2) Special set-up and alignment gauges
SKU: 555986
899.95 899.95
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
