Skip to Content
Bandsaw Basic Tune-up Kit
The Perfect Solutions to Get Rid of Squealing, Fix Worn out Tires or Essentials to Make Your Bandsaw Like New Again!
Bandsaw Standard Tune-up Kit (556083)
If your Bandsaw’s back-up rollers and guides are squealing and/or your blades are not tracking properly and affecting the accuracy of your cuts, this is the kit for you. The Bandsaw Standard Kit includes our Ball Bearing Back-Up Roller Retro-Fit Kit (555074) to eliminate your squealing problem and help your machine run smoother plus two replacement Rubber Bandsaw Tires and a bottle of Tire Adhesive.
Bandsaw Complete Overhaul Tune-up Kit (556084)
The Bandsaw Complete Overhaul Kit not only fixes issues where Your Bandsaw’s back-up rollers and guides are squealing and/or your blades are not tracking properly and affecting the accuracy of your cuts, but it also addresses another important issue as well. If Your Blades seem to dull quickly (even after installing a new Blade) if your machine seems to generate excessive heat, if it vibrates or if either (or both) of the Blade Wheels can be wiggled easily when the Blades are removed, you likely need the Overhaul Kit. The Bandsaw Overhaul Kit Includes: Our Ball Bearing Back-Up Roller Retro-Fit Kit (555074) to stop the squealing, an upper Wheel and Bearing w/Tire (502691), and a Lower Wheel Assembly with Tire, Bearing and Shaft (509032).
Bandsaw Backup Bearing Upgrade is for Older Model Shopsmith Bandsaws With Squealing Bronze Bushing Back Up Rollers, No More Squealing! (555074)
Being driven nuts by the squealing back up rollers on your older model Shopsmith Bandsaw? Here's your solution. These high quality, permanently lubricated ball bearing assemblies work with 1/16" through 5/8" blades to reduce blade friction and make your blades last a lot longer.
Compatible with all Shopsmith Bandsaws and has been standard with Bandsaws with serial numbers later than 97932. Kit components replace the bronze bushing upper, lower and auto-track back-up rollers. Easy to install in a matter of minutes and, best of all, No More Squealing!
Bandsaw Tire and Adhesive Kit (555644)
A worn bandsaw drive wheel tire causes vibrations and affects blade tracking.
The Bandsaw and Adhesive Kit (555644) Includes:
• Original Equipment Tire
• Special Adhesive
• Instructions.
Bandsaw Tire (Tire Only - No Adhesive) (518108)
Bandsaw Tire (only) Original Equipment Tire. Made to last. Heavy-duty, 1/8" thick. Requires Glue. Pair with 55644 Bandsaw Tire and Adhesive Kit to replace both tires on Your Bandsaw to make it run like new.
SKU: 556083
79.95 79.95
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
