Skip to Content
Premium Caster Upgrade (Includes: (4) 3 Inch Dia. Red Wheels and Drill Guide, Drill Bit and Mounting Hardware)
Move your MARK effortlessly around the shop—built for convenience, engineered for durability.
Shopsmith Premium Retractable Casters are designed specifically for MARK tools, making it easy to glide your machine from one location to another—even over garage or basement concrete expansion joints.
Built to Last
Constructed from rugged die-cast aluminum with solid steel rods, these casters feature a spring-loaded mechanism with three settings:
  • Step once to raise your MARK ¼" off the ground—perfect for smooth surfaces
  • Step twice to increase ground clearance to ½"
  • Step three to gently lower your MARK back into working position
Already have the Standard Casters? No need to repurchase brackets. This upgrade kit lets you swap in the premium 3" polyolefin wheels:
  • (4) 3" diameter by 1-¼" wide polyolefin red wheels mounted on rugged ⅜" steel axles with sealed ball bearings for smooth, quiet rolling. The casters swivel 360° for effortless maneuvering.
  • Quick Installation Kit
In testing, the Premium Casters required 50% less force to move a MARK compared to Standard Casters—making shop movement smoother and easier.
Need a replacement caster?
  • 3" Premium Caster Wheel (Red) – Part #522877
SKU: 556224
89.95 89.95
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
