Skip to Content
PATTERN SANDING GUIDE PKG (3 PC)
Shopsmith Pattern Sanding Guide Package
This simple 3-piece package (and a set of our Shopsmith drum sanders) is all you need to save loads of time by drum sanding multiple projects or components to the exactly the same size and shape. Just insert the appropriate sized guide into your Mark V or Mark 7 worktable miter gauge slot. Align the guide with the matching Shopsmith drum sander (2-1/4", 1-1/2", 1", 3/4", or 1/2") then tighten the clamping knob and your ready to go.
By attaching a shop-made pattern to the bottom of your workpiece (the included instructions tell you how to make and use these patterns) and then rotating your pattern/workpiece against the guide, you'll be able to sand as many projects or components to the same exact size and shape as you like. And do it much, much faster than if you were doing them one-by-one. A real time-saver!
Note: Not for use with ER, Mark 2 and older style Mark VII.
SKU: 556238
44.95 44.95
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
