Skip to Content
Premium Retractable Caster Assembly (Includes 3 Inch Dia. Red Wheels and Installation Kit)
Move your MARK effortlessly around the shop—built for convenience, engineered for durability.
Shopsmith Premium Retractable Casters are designed specifically for MARK tools, making it easy to glide your machine from one location to another—even over garage or basement concrete expansion joints.
Built to Last
Constructed from rugged die-cast aluminum with solid steel rods, these casters feature a spring-loaded mechanism with three settings:
  • Step once to raise your MARK ¼" off the ground—perfect for smooth surfaces
  • Step twice to increase ground clearance to ½"
  • Step three to gently lower your MARK back into working position
Includes everything needed to upgrade your MARK:
  • (4) 3" diameter by 1-¼" wide polyolefin red wheels mounted on rugged ⅜" steel axles with sealed ball bearings for smooth, quiet rolling. The casters swivel 360° for effortless maneuvering.
  • (2) Caster Brackets
  • Steel Drill Guide with Drill Bit
  • Mounting Hardware
  • Installation Instructions
SKU: 556247
199.95 199.95
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
