Skip to Content
120V Motor Replacement & Poly-V Drive System Upgrade
If you are experiencing excessive motor noise, slipping, straining, or overall poor performance of your Conventional Headstock with Gilmer Belt, it's time to upgrade to the quiet, highly-efficient Poly-V Drive System. The Poly-V Belt is a full 7/8 Inch wide with 9-ribs to grip the pulleys for full power transmission. The Poly-V Sheave has matching high-speed balanced grooves for smooth running performance. Drive Sleeve Assembly includes precision machined Poly-V Pulley with high-speed bearings and extra grooves for proper belt alignment. Double Bearing Quill Assembly is precision machined and factory-aligned with two high speed bearings for smooth operation under load. Gilmer-to-Poly-V Drive System Upgrade With Motor Includes: High-Speed, Two-Bearing Quill, Drive Sleeve Assembly, Poly-V Sheave, Poly-V Drive Belt, and easy to follow instructions.
SKU: 556492
799.95 799.95
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
