Skip to Content
28 Piece Drum Sanding Package (For All MARKS)
Drum Sanding is used for sanding the inside or outside of curved edges on project workpieces. These drums are as small as ½” Diameter up to 2-5/16” diameter and work for many project applications. Shopsmith drums and sleeves range from 6” long down to 2” long to work easily on thick-to-thin stock. The abrasives are Aluminum Oxide (A/O) for strength and durability and Garnet for sharp, fast-cutting edge sanding. All of the Shopsmith 2-5/16” Sanding drums mount directly onto the Quill Spindle with a quick turn of the 5/32” Allen wrench. The rest of these drums are installed in the Drill Chuck and secured with the Chuck Key. There is even a Multi-Sand Drum that uses 3 different grits on the same drum, so changing from coarse to medium to fine is as easy as extending the quill. Below you will find these drums are available as singles or grouped together in convenient packages. No longer will you have unsightly, rough curved edges on your workpieces.
Shopsmith 2-5/16" x 3” Long Drum Sander with Sanding Sleeve
The 2-5/16" Shopsmith drum sander is 3" long with a rubber expansive drum that can be attached quickly to the spindle on Your MARK, Shopsmith Power Station, or the auxiliary spindle on your Shopsmith Belt Sander. Just slip the sleeve on, tighten the expansion bolt, and go to work. The 3” long sleeves are made with tough, long-lasting A/O Abrasive. They come in 6-packs of 60, 80, and 100 Grit sleeves as well as an assorted 6-pack of 2 each 60, 80, and 100 Grit sleeves. Includes: Drum Sander and One Medium Grit Sanding Sleeve.
Shopsmith 2-5/16" x 6" Long Drum Sander with Sanding Sleeve
The 6" long x 2-5/16" Shopsmith Drum Sander does everything our 3" long model does and more. For example, use it to sand the inside or outside curves on workpieces up to 6" thick... or to pad sand a stack of several 1/2" or 3/4" thick workpieces to the identical shape, all at once! They are also made with tough, long lasting A/O Abrasive. They come in 6-packs of 60 Grit, 80 Grit and 100 Grit sleeves as well as an assorted 6-pack of 2-each 60 Grit, 80 Grit and 100 Grit sleeves.
Another great way of using this 6” long Sanding Drum is to put a 3" long coarse sleeve on the bottom and a 3" long medium or fine sleeve on top and switch between sanding grits without changing sleeves by simply moving Your MARK Quill up or down. The vacuum attachment must be extended for this operation. Includes: Drum Sander and One Medium Grit Sanding Sleeve.
Quick Solution For Proper Three-Grit Drum Sanding Without Switching Between Multiple Drums!
The experts will tell you that achieving the highest quality, smoothest wood finish must start with a perfectly smooth surface. Achieving that smoothness usually means incrementally sanding raw workpiece edges with coarse, medium, and fine grit abrasives. Skip a step and you may end up with results that are less than desirable.
If the smoothness you seek is to be on a curved edge or surface of a workpiece, the best tool for the job is likely a drill press-mounted stationary drum sander.
The Normal 3-Step Changeover Process:
First, Install a coarse sleeve to remove the majority of the sawing marks. Then Remove the Sanding Drum from your machine, use a wrench to loosen the expansion bolt and remove the coarse sleeve. Replace that coarse sleeve with a medium sleeve, tighten the expansion bolt and repeat the process. When you're satisfied with the results, repeat the process again by replacing the medium sleeve with a fine sleeve to complete your final step.
Multi-Sand Sleeves Eliminate the Changeovers and Get the Job Done Faster!
What if you could cut those three installation steps down to just one — and spend more time sanding and less time changing? Now you can, thanks to the Shopsmith Multi-Sand Drum Sander and Sleeves!
Here's How It Works:
Install a 2" long x 2-5/16" diameter fine grit Multi-Sand Sleeve, sliding it all the way to the top of the 6" drum followed by a 2" medium grit sleeve, and finally a 2" coarse grit sleeve. Tighten the expansion bolt once. Attach the sanding drum to your spindle and you're ready to start sanding. We used Garnet Sanding Sleeves for this Multi-sand System because they are fast cutting and leave a smooth surface.
Your MARK gives you 4-1/4" of up-down quill travel. This means you can go through all three steps of the sanding process on any piece of stock up to 1" thick by simply moving your quill down for each subsequent step. With no sleeve changing, nothing could be simpler or faster. Forget a step? No problem. Just move the quill to the desired grit and sand away.
Getting Started with the Multi-Sand system Is Amazingly Affordable!
If you already own our 6" drum sander, all you need to get started is a package of our assorted Multi-Sand Sleeves. If you don't yet own a 6" high drum sander or any of the optional drum sanding table inserts or vacuum attachments, order the appropriate Multi Sand Starter Package and get everything you need to get started!
Complete Multi-Sand Starter Package Includes:
• 6" x 2-5/16" Drum Sander
• 1 Each Coarse, Medium, and Fine 2" long Sanding Sleeves
• Vacuum Attachment
• Vacuum Extender
• Table Insert
28 Piece Drum Sanding Set
The Shopsmith 28 Piece Drum Sanding Set of Sanding Drums and Sleeves are all Drill Press Mounted Drums and a great starter package for drum sanding. The sleeve abrasive is A/O. Simply slide the sleeve on the drum and tighten the compression nut to expand the rubber drum and lock the sleeve on the drum. Then simply mount the drum of your choice in your Drill chuck with the Chuck Key.
28 Piece Set Includes:
• (4) Sanding Drums 2" x 1/2" Dia., 3/4" Dia., 1" Dia., 1-1/2" Dia.
• One Set of (3) Fine (2) Medium (1) Coarse Sanding Sleeves for each Diameter
Buy additional Drums of each size so you can keep each grit on its own drum. Then, instead of changing sleeves on a single drum you will have different drums set up for quick installation in the drill chuck.
37 Piece Premium Drum Sanding Package
The Shopsmith 37 Piece Premium Drum Sanding Package has everything you need for sanding inside and outside curves and contours, all in one package. Saves hours of tedious hand sanding.
37 Piece Premium Drum Sanding Package Includes:
• 2-5/16" x 3" high Shopsmith Drum Sander
• 6 Assorted Sleeves ((2) Coarse 60 Grit, (2) Medium 80 Grit (2) Fine 100 Grit)
• (4) 2" Long Rubber Expansive Drums (in 1/2", 3/4", 1" & 1-1/2" diameters)
• 3 Fine, 2 Medium and 1 Coarse Grit Sleeve for Each Size
• Shopsmith Drum Sanding Table Insert
• Shopsmith Drum Sander Vacuum Attachment
It's all here! Available in two different versions to suit your particular MARK model. Note: Not for use with ER, Mark 2 and older style Mark VII.
Shopsmith Pattern Sanding Guide Package
This simple 3-piece package (and a set of our Shopsmith drum sanders) is all you need to save loads of time by drum sanding multiple projects or components to the exactly the same size and shape. Just insert the appropriate sized guide into your Mark V or Mark 7 worktable miter gauge slot. Align the guide with the matching Shopsmith drum sander (2-1/4", 1-1/2", 1", 3/4", or 1/2") then tighten the clamping knob and your ready to go.
By attaching a shop-made pattern to the bottom of your workpiece (the included instructions tell you how to make and use these patterns) and then rotating your pattern/workpiece against the guide, you'll be able to sand as many projects or components to the same exact size and shape as you like. And do it much, much faster than if you were doing them one-by-one. A real time-saver!
40-Piece Complete Pattern Drum Sanding Kit
If You Don't Currently Own One of Our Drum Sanding Packages, Order Yours Now With Our Complete Pattern Drum Sanding Kit and Save !
40-Piece Complete Pattern Drum Sanding Kit has everything in the Individual drum Sanding Packages combined together, all in one package
Includes:
• 3-Piece Pattern Sanding Guide Package
Note: For all Shopsmith MARKs except MARK V Model 500. Also, Drum Sanders must always be used with the Drum Sander Table Insert. Dust Collection is always recommended when Drum Sanding. We advise you to always wear an N95 (NIOSH-Certified) Respirator when sanding to filter out 95% of airborne particles.
SKU: 750148
69.95 69.95
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
