Skip to Content
ShopSlick Surface Protector
ShopSlick Surface Shield & Glide System
Slicker than Metal. Protects from Rust. Cleaner and easier than Wax.
Say goodbye to the endless cycle of scrubbing rust and buffing paste wax. Patent pending ShopSlick is the ultimate upgrade for your metal machine work surfaces—a renewable, ultra-thin UHMW protective film designed to give your cast iron and other machine surfaces a surface smoother than factory-polished steel.
Whether you're battling rust causing humidity, sweating through long shop sessions, or ripping damp lumber, ShopSlick creates an airtight, hydrophobic barrier that stops flash rust, sweat corrosion, and table "suction" in their tracks. Wood glides effortlessly across your table saw, jointer, and custom jigs without the stuttering that leads to kickbacks or blade burn.
Why Woodworkers Are Switching to ShopSlick:
  • Slicker-Than-Factory Glide: Reduces friction by up to 300% compared to dry cast iron and 50% compared to paste wax, eliminating table drag on even the highest-moisture lumber.
  • Atmospheric Armor: Creates a  waterproof seal to protect your machine tables from ambient humidity, condensation rings, and accidental spills.
  • 100% Finish-Safe: Unlike paste waxes or silicone sprays, ShopSlick’s chemically inert surface leaves zero residue on your wood—preventing costly "fish-eyes" and staining issues.
  • Fast Peel-and-Stick Application: At just 0.005" thin, it applies in under 5 minutes without throwing off tool calibrations or scales. Simply cut to fit any main table, rip fence, router base, or miter bar.
  • Zero-Residue Renewal: Built with a specialized non-ghosting adhesive that peels away cleanly when worn, taking the daily wear-and-tear so your ShopSmith and power tools retain their factory-new resale value underneath.
Stop spending your hard-earned shop time maintaining your tools. Apply ShopSlick once, protect your machinery forever, and enjoy the smoothest feed of your life.
SKU: 580001
39.95 39.95
  • ShopSlick Lengths
Terms and Conditions
30-day money-back guarantee
Shipping: 2-3 Business Days
Specifications
ShopSlick Lengths ShopSlick Surface Protector 24" W x 24" L, ShopSlick Surface Protector 24" W x 36" L, ShopSlick Surface Protector 24" W x 48" L
